Solaire
DJI Mindy Posted at 2017-7-31 22:42
Solaire, the frame rate of Slow Motion is 100fps. 1920x1080 SLO means Slow Motion.
May I have more details that you cannot select 4K? The option is grey? Could you please show us the screenshot? The picture below is the option in NSTC standard:
Hi Mindy,
Thanks a million for the response. I'm at work but will screengrab soon as I'm home.
100fps suits perfectly actually, once I can get the "slow-motion" mode to select, as I'm working with PAL 25fps outputs.
Note: in the settings I did switch from NTSC to PAL - I'll see if the problem persists after switching back to NTSC (once I can shoot on an fps divisible by 25 I presume this won't affect me)
None of the options are greyed out, and all are selectable (blue tick beside) except for "4k" and "Slow-Motion", tapping them simply does nothing and the currently selected mode remains selected.
As I said I have a "1920x1080 SLO" mode which is selectable but crops the sensor to full optical zoom, which is not ideal.
***note: I recall that in the other video option (via the filmreel icon), the only options available are "auto" and "slow" - but I've seen screengrabs from other users with apx 5 modes under this icon. Again I'll provide a screencap when possible. The default "auto" keeps the selected video mode active (eg 1920x1080 25), and "slow" switches to the aforementioned "1920x1080 SLO" mode. I'm not sure if this is indicative of anything or is standard, but they are the only options for me.
Thanks again for the response. |
