DJI GO Request: Camera Yaw Correction
2724 14 2017-7-31
120ccpm
Flight distance : 1396755 ft
Hello DJI,
the camera of my P3 Standard has been pointing just slightly to the left since day one (it's almost un-noticeable, but it's there). IMU and gimbal calibration don't seem to correct the issue, so it must be a mechanical thing where the camera body is not perfectly aligned on the yaw axis.
It would be ideal if you could add a gimbal yaw correction in DJI GO, similar to what we already have for tilt. I've read of people twisting the yaw arm a few degrees, but it seems a bit extreme for something that could easily be corrected via firmware/app.
2017-7-31
Peterx
Flight distance : 1499708 ft
Try the gimbal adjust in the gimbal menu.
2017-7-31
120ccpm
Peterx Posted at 2017-7-31 13:42
The only things you can do from the gimbal menu is Adjust Gimbal Roll, and Gimbal Auto Calibration. I'm asking for a third option to Adjust Gimbal Yaw, to correct for small mechanical misalignments on the yaw axis, similarly to what Adjust Gimbal Roll does for the roll axis (tilted horizon).
2017-7-31
DJI Susan
Thanks for bringing this to our attention. I have reported this request to our engineers and hopefully they will consider it.
2017-7-31
Peterx
I forgot that. Is the screw on the yaw axis fasten or loose?
2017-7-31
120ccpm
Peterx Posted at 2017-7-31 22:38
Not sure I understand your question... I know there is a grub screw on the yaw axis becase I've seen posts from people reporting it to get loose with time, but:
- I believe the screw pushes against a flat spot on the axis, which means it's not designed to make adjustments
- I'd rather not touch things, especially under warranty
2017-8-1
CornGuy
DJI Susan Posted at 2017-7-31 19:07
Any update on the potential for adjusting the gimbal yaw from the Go app?
2017-8-30
ALABAMA
Flight distance : 10442687 ft
PeterX is correct.  Very small allen wrench will tighten the grub screw at top of yaw arm. You may have to swing the arm to see it.
2017-8-30
DJI Susan
CornGuy Posted at 2017-8-30 14:43
Sorry, we have not got the notice for now. We will release on our official website if there is any update.
2017-9-1
fans51ffc175
I have an option on my DJI Go App called "Recenter Gimbal" but all that seems to do is make the camera face down and I'm not really sure what it's supposed to do. Can anyone explain what it does, how long it takes, what to expect, etc? My camera sits slightly to the left (YAW) by about 5 degrees and I cannot overcome this.
2017-12-5
fans51ffc175
Does "Recenter Gimbal" have any affect?
2017-12-5
stuka75
Flight distance : 85682 ft
Does the video yaw to the left?
2017-12-6
DJI Braly
stuka75 Posted at 2017-12-6 05:55
The camera is facing slightly left after the drone powers up. See this video for full details of my problem:
2017-12-6
ALABAMA
Sometimes the yaw motor shaft can be off center. That can easily be  fixed by taking the cover off and aligning the flat side of shaft.
2017-12-6
DJI Braly
Looks aligned when I inspected it.
2017-12-9
