Live Streaming to YouTube or Facebook
767 2 2017-7-31
Danjahmouse
Flight distance : 163474 ft
New Zealand
How many of you have tried streaming to FB or YT? Have you tried by using home wifi and what framerates do you get? Ive tried both FB and YT on home Wifi AND data but seem to only be getting crappy framerates that go from 30fps to .5fps gggrrr. Is there a way to fix this if at all? Im assuming it will have a lot to do with the type of connection to wifi OR data and the quality of the connection....
Cheers in advance
2017-7-31
patman89
Flight distance : 288327 ft
Tried it once and had a different issue. I had some stream interruptions but between these interruptions there was not frame-rate problem. Tested it with DJI Go 4.0.5 didn't tried it with the latest app so far.
2017-8-1
Mari
Flight distance : 1308780 ft
You need some bandwith to get higher framerate during streaming. Check up/download of your internetconnection. If you internet connection is not fast enough it will not work properly.
2017-8-1
