MOV to MP4
7852 21 2015-3-24
pidetectives
Flight distance : 2131073 ft
Today by mistake a recorded on MOV. on my inspire. I need to convert it to MP4. I NEED HELP
2015-3-24
rfrye
Flight distance : 309606 ft
Pidetective,
I have used Movavi Video Converter. I think you can get a free trial (7 days) download to see if you like it before you subscribe to the software. I ended up subscribing and use it occasionally for various tasks. Check this free trial period - it may have changed.
Here's a link:
http://www.movavi.com/videoconve ... nw8QCFQyqaQodM0cAhg
I'm sure there may be others (like Jim Hare, Marco & dbeck)) with better advice- so you may want to check my suggestion.
2015-3-25
Acidsnow
Flight distance : 13 ft
you can actually just rename from *.mov to *.mp4 - those extensions are just wrappers really . . .
2015-3-25
pidetectives
Acidsnow Posted at 2015-3-25 20:37
How do I do that. Please help me with this
Than you
2015-3-25
pidetectives
How do I rename it to mp4. Please help me with this
thanks
2015-3-25
pidetectives
rfrye Posted at 2015-3-25 18:35
Pidetective,
I have used Movavi Video Converter. I think you can get a free trial (7 days) download ...
Thanks it converts it bit but still will not let me see it in windows player or movie maker
2015-3-25
Acidsnow
if you are using Windows right click, select rename . . .
2015-3-25
CrabHawk
Flight distance : 7782 ft
You can go on internet and look up " Movie Converter for Windows"
2015-3-25
CrabHawk
go here. http://download.cnet.com/windows/video-converters/
2015-3-25
rfrye
pidetectives@ya Posted at 2015-3-25 22:02
PI,
Again, check my suggestions .. I have downloaded VLC Media Player which always plays my videos. It is also a free down load, but get it from http://filehippo.com/ to prevent getting a bunch of other garbage you don't want on your computer.
Also PI, - if you go to this link in this form you'll see another discussion on this (you'll have to page down a bit).
http://forum.dji.com/forum.php?m ... age%3D1&lang=en
Hope you get a solution.
2015-3-25
pidetectives
My issue is I need to edit it And give it to someone in mp4. Software converters it but still can not see it in Windows player or Windows movie maker.
2015-3-25
rfrye
pidetectives@ya Posted at 2015-3-26 00:24
My issue is I need to edit it And give it to someone in mp4. Software converters it but still can no ...
what are you editing with? Premiere? Final Cut?
If one of those - you can select the file type you need to export in -
2015-3-25
pidetectives
rfrye Posted at 2015-3-26 01:10
If one of those - you can select the file type you ...
I am editing with Windows movie maker. That's why I need to convert it to mp 4
2015-3-25
fionaeagle
You can try MOV to MP4 Converter to do the program.  Here is a full guide on .mov to .mp4 conversion. Hope it helps.
2015-4-23
malfoyerik
India
For playing MOV video files on other portable players, you must opt for good video camera/camcorder converter software that can modify videos into any desired format such as MPEG-4, FLV, AVI, MKV, SWF, MPEG-2, 3G2, 3GP, WMV, M2TS, MPEG-1, ASF, M4V, VOB, MPG, etc and also changes audio formats as FLAC, AU, MP3, AMR, AIFF, M4V, OGG, WAV, MP2, WMA, etc without hampering the original quality. Video Converter tool is best option for this purpose; it’s particularly designed to convert MOV videos into any other desired formats for enjoying it on your portable gadgets.
2016-6-6
DJI-Ken
Flight distance : 1515312 ft
pidetectives@ya Posted at 2015-3-26 01:14
Were you able to convert it by finding something online?
2016-6-6
Tharg (from the
Flight distance : 120784 ft
Don't bother faffing about and wasting time with converters - it's pointless.
Just rename the extension to .mov
Nearly all NLE's will read the file then as a .mov wrapper (codec and GOP structure is identical)
2016-6-6
RichJ53
Flight distance : 1837356 ft
pidetectives@ya Posted at 2015-3-25 10:14
Tharg is correct, you only need to rename the file in windows DJI_0009.MOV to DJI_0009.MP4  then it will work just fine in windows player. I just took my P4 video and renamed it and it plays perfectly. imported the renamed file into movie maker .. worked fine
no worries
Rich
2016-6-6
Positveimage
Flight distance : 2772 ft
Hi Guys,
Download "Free MP4 Converter" from the App store, It will do this and much, much more...
2016-6-7
djiuser_kH6j0llAAjUE
China
I have met the same problem before and found the 3  solutions from videoconverter.wondershare.com/convert-mov/convert-mov-to-mp4.html, which tells you how to convert MOV to MP4 with free desktop converter, online converter. Also you could directly use the free online converter, such as keepvid.cc.
2018-2-3
ambercliman
if you have video file needs to be converted from mov. to mp4. you can try this 2 sites:
totally free mov to mp4 converter: https://www.keepvid.cc/mp4-converter/
professional mov to mp4 converter: https://www.keepvid.cc/keepvid-video-converter/
I always use these 2 sites. easy to use.
2018-2-26
djiuser_ulcwlkHEFv1g
Philippines
There are several sites that you can use to convert your videos to different formats. But most converters only convert videos from community sites like youtube, Vimeo, or Dailymotion. At times you will get error messages that it can't convert the video. You can try Acethinker's online converter, Clipconverter, Video grabber, Converto.io, Freemake video converter, and Video Keeper. I personally use Video Keeper since it works almost on all types of format. I hope this information can help.
2018-5-30
