Giodonk
Flight distance : 43599 ft
P4Mano Posted at 2017-8-21 05:29
Hello rayloo
You should try to fly a little further!
Because 200m is a short distance to know if everything is okay with your P4 !!
In my experience, a weak signal is usually caused by one of two things.
1) wifi has not been switched off and causes heavy interference.
2) antenna orientation. If AC is directly overhead, antennas on RC need to be horizontal.
If AC is in the distance, antennas on RC need to be vertical. Otherwise the tips of the antennas will be pointing at the AC and very little signal is radiated from the tips of antennas. |
