Aardvark
Flight distance : 384432 ft
Eric ncfwa Posted at 2017-8-4 05:16
I read in another thread that you should format the SD card each time you reinstall it into the AC, is this true? I usually remove the card from the AC download the footage onto my computer then delete the footage from the SD card.
Regards
Eric
I usually use the format in aircraft to delete/format the card when it needs to be emptied. There shouldn't really be much need to do it each time, but if that is your process then I can't see it would do any harm. |
