Hi, i have a strangr problem that the dji go 4 app suddenly aligned right instead left.. how do u fix this? The rth and land marks are at the right side covering rhe camera button
It sounds like it has something to do with a setting on your phone or tablet. All I can suggest is to uninstall the app, restart your phone or tablet and then reinstall the app.
I still think it is caused by something that has changed on your phone or tablet. Has there been a firmware update to your phone/tablet, have you loaded any new apps that have some control of the screen, have you changed resolution on the screen?
I had the same problem. Probably your default language in your smartphone is not English.
All you have to do is to set your default language to English and the problem is solved.
I had the same problem. Probably your default language in your smartphone is not English. All you have to do is to set your default language to English and the problem is solved. Hope it helps
