Tzuli
Flight distance : 346637 ft
Slovenia
DJI Thor Posted at 2017-8-5 23:51
Please check the flowing steps:
First, please check whether the firmware had upgraded completely. Sometimes the firmware version with a +/- mark behind means the upgrading incomplete. You can check the version by this way: power on the drone, RC, app and enter device---upper right icon---general----about.
Second, Please check could you control the gimbal by RC? If the gimbal doesn't move, please try to relink the drone and RC. If you can control it, please try to replug the connecting cable between the RC and the device or change to the original connecting cable of your mobile device. You can plug the port on the bottom of the RC, but need to pull out the cable on the left side first.
Hi
Thank you very much for your reply
1. All my firmware upgrades are current, no +/- anywhere
2. I was able to control the Gimbal during the signal transmission loss
- I did not have an extra cable on me was sure that a device that is 5 days old should work. I have connected/disconnected the cable many times between repeated takeoffs no success, image loss happened every time
- I do want to use the original RC Cable, it is far more convenient for my configuration
3. will reinstall although why were there a few successful flights?
4. Not sure what you mean by that? Change location? The video transmission loss happened at two very different locations.
I am really disappointed, I have a drone I can not trust, I carry it in my backpack not knowing if I will be able to shot video with it or not. On top losing time on the forums looking for solutions... |
