Cetacean
Flight distance : 2528264 ft
Aloha fans577,
This sounds like a real pain. On the up side you have two compasses. Have you gone into the DJI GO 4 app and looked at your compass read-outs? Unfortunately, any attempt you may make to re-seat the cable will void your warranty. The connection is inside.
In the General Settings (Icon in upper right corner) tap on the Aircraft settings icon (top left). In there look for Sensors and tap on it. Then tap on the compass option and check the two compasses for their performance information. If the compass 2 shows good performance and you have already calibrated it, give your bird a test flight. Let us know how it goes.
If the stars are aligned right for you, this might buy you enough time to do your shoot and then get the Aircraft fixed. On the other hand, what you are experiencing is the reasoning behind having a back-up.
Hope this helps!
Aloha and Drone On! |
