E1200 Propulsion System
4576 13 2015-3-25
Tahoe_Ed
Flight distance : 2605 ft
DJI just announced the new E1200 Propulson System,  On the S900 it will provide an additional 1.8kg of lift.  Here is the introduction video.
I hope you enjoy.
2015-3-25
andre.staehli.b
Flight distance : 4313343 ft
Switzerland
Motors dampers are eaten after 5 to 10 flights. These small rubber pieces are too weak and not strong enough to support the tork et the vibrations of the motor. I had an issue where all 4 dampers are full filed on a motor and the result was a very unstable flight and a big noise.
I mind that this fixing system is to be upgraded by DJI. Inbetween i correct this by mounting 3 o-rings in place of the rubber damper, one under the bottom piece et two up the bottom piece of the motor. O-rings are EPDM inner dia. 3 mm, height 2 mm. This solutions is much more rigid and seems to be a sustainable solution.
2015-10-28
rogerkapsalis
Flight distance : 1340610 ft
wowie716 Posted at 2015-7-23 05:45
I cant find videos in the internet/youtube in how to change the 6 original mitors/frames of the S900 ...
Just use the ESC app. Switch from Red to Green. Simple.
2015-8-15
wowie716
Norway
I already purchased the dji updater directly from dji china..but i cant move on because im still looking a link or videos in doing so...can any body from DJI to provide a videos about this matter?..thank you
2015-7-22
wowie716
Norway
I cant find videos in the internet/youtube in how to change the 6 original mitors/frames of the S900 to E1200 S900 pro tuned propulsion system and to changed the green led lights to red led lights...may i request from DJI  to post videos?. Thank you in advance
2015-7-22
DJI-Dave
The E1200 looks like a great system. One day I will have to get one setup for myself.
2015-7-16
dom.dompiccini
Tahoe_Ed Posted at 2015-3-31 08:41
I got a chance to fly my S920 today with the E1200 propulsion system.  It was great!    My initial ...
What were your final gain settings?
2015-5-28
Tahoe_Ed
cravac Posted at 2015-5-25 23:15
Any idea when we'll be able to purchase I1 replacement motors?
I do not.  Right now it is not considered a user replaceable item and requires service at DJI.
2015-5-25
cravac
2015-5-25
Tahoe_Ed
signirr Posted at 2015-4-23 00:06
DJI e1200 ordered, paid and not shipped.
I have contacted DJI.  They will give you the option to cancel your order for a refund or wait until stock is available.  It will be your choice.
2015-4-30
zentinel
Switzerland
Here's another Video
I've found a gain settings which fits the S900 & Wookong setup better than the A2 settings from the manual:
Basic Pitch 120, Roll 120, Yaw 85, Vertical 60
Atti Pitch 138, Roll 138
Will test this gains tomorrow and will post a video
2015-4-30
RichJ53
Flight distance : 1837356 ft
can't watch permission denied ...
2015-4-13
Tahoe_Ed
I got a chance to fly my S920 today with the E1200 propulsion system.  It was great!    My initial tests were over asphalt and it was light.  I took the GH4 gimbal and camera off and only had my FPV camera through the Lightbridge on.  I used the default gains and had no issues at all.  Punch outs were a little slow but that may have been because I was in GPS mode.  Full down descents were only coupled with very light flutter at the end.  My android phone crapped out do to heat half way through the flight and so I don't have any telemetry to explore the efficiency.  Tomorrow I will be flying with my GH4 gimbal and camera.  Looking forward to it as my GH4 is now working through my Lightbridge and outputting to my Atomos Ninja Blade.  I should be a great day!!!
2015-3-30
Eirlink
very nice . well done Dr T, and the team at DJI
2015-3-27
