Bekaru Tree
Flight distance : 15513100 ft
South Africa
Nazar78 Posted at 2017-8-6 07:36
This should help, I usually use option #2 to reboot and disable driver signature enforcement: https://www.howtogeek.com/167723 ... l-unsigned-drivers/
Just in case while still on the same Win10 topic, I have another issue with sdcard and mavic storage not appearing in Win10. I found out a "workaround" by going into the device manager, while mavic is still connected, uninstall the disk drives drivers (there should be two) then rescan hardware changes then the sdcard (pics/vids) will appear in win exporer. If trying to view the mavic internal storage, do as per the above after clicking on the flight records then the internal drive (with *.dat files) will appear.
Thanks Nazaar - i followed option 2 and got past signed driver requirements.
Now i am stuck a few steps on- when i open flight data in assistant 2 a Viewer screen opens.
here i have selected a new sheet and then clicked on a file to open.
The file then loads 0-100% but then....nothing and no prompts of what to do next or what went wrong.
Any ideas? screenshot of my latest sticking position below.
Thanks again for yr help on the signed drivers issue - much appreciated. |
