Video stream issue solved
590 2 2017-8-7
Duchunter
Ive been having issues with my video feed cutting in and out. I noticed that taking it off of auto and locking it on a channel solved my issues but now I figured out why. I noticed that as soon as I put it back to auto the video feed got bad again. When I would put it back on manual the the bit rate would be on 6 mbps. When I put it back on 4 mbps the video cleared up. For some reason the auto channel select raises the bit stream rate. When its on auto it doesnt tell you the rate. You only see what its on when you go back to manual. In the pic showing it at 6 mbps was after taking off of auto. If you change it to 4 and put it back on auto it will go up to 6. You have to leave it on manual and change it to 4 and pick a clean channel. Hope that helps some of yall.
2017-8-7
BagoDJIoperator
Flight distance : 1077608 ft
Thanks maybe I will try it, since I been having signal issues when I fly, Thanks for the recommendation.
2017-8-7
Duchunter
BagoDJIoperator Posted at 2017-8-7 09:36
Glad to help. I hope it works for you. It completely resolved my issue and made my android tablet usable.
2017-8-7
