Ups_Jeff
Flight distance : 434931 ft
RichJ53 Posted at 2017-8-14 19:39
Jeff
Not to bad of a challenge for me I am pretty sure with proper guidance or instructions, this could be done by less experienced folks. Yes, the icharger setup is expensive and it was overkill for this project. You can do this procedure with a more simple less expensive solution. Most modelers have a LiPo battery charger around for airplanes and helicopters etc. you could use a $70 charger to complete this project
I have 3 batteries, and two of them don't show the battery cells being depleted in the go app, once the battery drops below 50%. I have the voltage show on the main screen as I fly, and that works perfect, but if you click on the battery to look at the cells, once they hit 50%, no data changes. I can't figure it out, and I am not sending it in over that. I get the information I need on the main screen. Since one battery shows the information correctly, I am thinking it has something to do with the battery, and not the bird. I need to drain the other two batteries to like 5%, and see if a reset works. |
