Labroides
Flight distance : 9991457 ft
No. The manual is pretty sketchy about how far it will retrace but the Phantom can't store a full map for a long path and when you lose signal, because you fly behind an obstacle, just coming back a short way is usually enough to reconnect
Here's what the manual says: The Forward Vision System allows the aircraft to create a real-time map of its flight route as it flies.
If the Home Point was successfully recorded and the compass is functioning normally, Failsafe RTH will be automatically activated if the remote controller signal is lost for more than three seconds. The aircraft will plan its return route and retrace its original flight route home. The aircraft will hover for 10 seconds at its current location. When it regains signal connection it will wait for pilot commands. The Return-to-Home process may be interrupted and the pilot given control of the aircraft if the remote controller signal connection is re-established |
