Punchbuggy
Flight distance : 483166 ft
As DJI Susan states, the P4 batteries are physically compatible with the P4P. However, for them to work the battery firmware must be at a compatible level for the craft. At the moment, the battery firmware is the same between the current releases of the P4P and P4. However, once DJI release the next P4P firmware, they may not be (if it incorporates an updated battery firmware). You'll find out if you install a battery into either craft and GO tells you that there's a "Firmware incompatibility", and you'll have to do a firmware refresh to get the battery compatible with that craft again.
I mention this as I know you have a P4, Jim, and you may be wanting to fly them both. If the firmware gets out of sync again, a solution is to keep some batteries aside for the P4 and some aside for the P4P. Or just fly one of them using all batteries. Or don't upgrade firmware on both craft any further.
I hope that made sense. |
