Mark Guille
Flight distance : 2031818 ft
Jersey
Have you updated the drone like Thor suggested in 2#, if not, try updating it with the X3 camera on, using the latest X3 firmware (on a freshly formatted SD card). Update the aircraft FIRST, with the controller OFF. When this has successfully completed, update the controller with the aircraft OFF. When you have everything up to date (except the X5), put the X5 firmware on the SD card and insert into the aircraft (with the controller OFF). You should now hear the D-D-D-D.
Good luck and don't forget to let us know how you get on.
Mark G. |
