Early bird
885 3 2017-8-12
Zamboon
Flight distance : 1332844 ft
Zambia
I have found that I am able to go much further and the craft is much more responsive early in the morning and to a lesser extent late evening.
Why is this? Temperature, humidity, solar or radio interference..... Any ideas?
2017-8-12
Bekaru Tree
Flight distance : 15513100 ft
South Africa
What are yr typical late evening weather conditions? Is Zamboon from Zambia perhaps? what country are you flying in.
2017-8-12
Bekaru Tree
South Africa
my recent research is showing that temperature and humididty do affect radio signals - trying to clarify that in this forum - not many opinions yet. if you google yr questions you will find that there are some technical pdf reports that say yes to yr question - i did not yet find any that say no.
2017-8-12
15matjan
Flight distance : 1158258 ft
Both are valid and possible. Supossing you are not affected by tail or front winds, solar interference can be checked on http://www.swpc.noaa.gov/, look for the estimated planetary k index. If 4 or above, expect possibility of erratic behaviour.Another factor could be temperature, i.e, air density, the colder air you fly, more air density and better sustentation.This means less rotations and lesser consumed energy/battery
2017-9-20
