zzz
Flight distance : 136086 ft
Our recent implementation put a sensor and a small computer on M600 to do some aerial sensing works (sensor not compatible with M600 input port). The M600 is manually controlled with controller and the computer just save the data captured by the sensors. We need to operate the computer when the UAV is in the air to start/finish the sensing job (Can not start from the ground for some reason).
Up to now, we have tried two setups but fails to make it work. First, we use a remote desk (such as teamviewer, tvnjviewer) connected the computer on the craft through WIFI, it looks like the wifi signal will be interferenced with the GPS of m600, so we discard this plan. Then, we tried the local way by connecting the HDMI port of the computer to the craft and operate the computer with a Logitech M510 wireless mouse & keyboard combo, it fails either because there is still a signal interference between the craft (when it is on) and the wireless mouse (Both channels are at 2.4 GHZ).
We are still searching for more options that can safely operate the computer while the UAV is flying. Any commment or suggestion is appreciate.
Thanks,
