POLL: Would you purchase a harness to fix TB-47/8 batteries??
RichJ53
Flight distance : 1837356 ft
DTK Posted at 2017-9-13 06:02
Hi Rich, it seems that you are now in production. I am in Australia. What would the cost be getting this cable connection made? Want to get 5 sets.
DTK
I just received a few parts for another prototype unit. I have not gone into production quite yet. I see that you are interested and I really appreciate that. Hang in there and I will keep you posted soon
Rich
2017-9-13
DTK
Flight distance : 1943159 ft
Since I have been inherited with a troublesome TB48 which has a few weak cells in it. I have individually balanced them a few times but the issue always recurring. It is a pain to open the cover and much more pain to individually balance them. So I have done the harness myself using a cable from another dead TB47. Once it is done, it can be balanced with my Venom Produo charger, very similar to Rich's icharger. Now with the balancing cable, the battery can be left alone and balance charged. Anyone who has these "intelligent" batteries should need one. Down the track, you would need one to do a "real" battery balancing charge. So it will be a good news when Rich is ready for production. At the moment, the advice is to run the battery down to 5% and the circuitry reset the cell charge information and "hope" that the following recharge will balance the cells. It does not work every time, it works probably when the cells with the battery are relatively in comparable strength. With one out of spec weak cell, the balance charging will be faulted.
Discharging to 5% or lower will also kill battery life. Lipo battery should be limited max discharge to around 20%. If you drain your battery down to below 10%, your battery capacity will roughly reduce by 100-120mah. So with a TB47 's capacity of 4500mah, it will not last very long. Even in normal use, every discharge and recharge will cost you about 20-30mah. DJI's claim of useful life about 200 charges is challenged here. After 200 counts, conservatively the capacity of the battery will be down to a couple hundred mah, the flight time is probably a couple of minutes.
2017-9-26
RichJ53
DTK Posted at 2017-9-26 13:49
DTK
Nice work and yes this is a great way to access the battery for additional maintenance. I sent out a harness to Mark and he will be doing some similar testing. Yes, the batteries are a bit of work to take apart. If you use the right tools from IFixit it can be a lot easier.  My Youtube videos were taken with my iPhone and I am not very proud of the quality.  Should be posting this anyway just to help get the information out there
Doesn't seem to be much interest from many members.  My investment for the required minimum might not work out. Should know very soon
Rich
2017-9-26
DTK
I will help to bump up this thread. To be honest, I was surprised when you started this thread. How can your new battery become imbalance only with 1 charge count. A lot of people will understand that this is a bloody expensive hobby or work equipment. The users need to roll up their sleeves and acquire some basic maintenance skill.
2017-9-26
RichJ53
DTK Posted at 2017-9-26 19:50
Unfortunately my supplier has told me the minimum quantity has gone beyond what I can manage for this project. I am looking for another solution again.
Rich
2017-10-9
DTK
What people can do is to get the cable from a spent TB47/TB48 and send to Rich. Recycle what can be savaged is always a good thing.
2017-10-9
RichJ53
DTK Posted at 2017-10-9 20:00
I believe you can make 2 harnesses from one old Inspire 1 battery.....The cable has a connector on both ends.. one socket can be trimmed down to fit, plus the original one for the battery connection.   I was hoping to have these made professionally to keep the costs down. Making them one at a time is pretty tedious but possible.
All the best
Rich
2017-10-9
DTK
One end of the cable has 2 more wires connected to it. It probably getting data from circuit board. Only the end connect to the Lipo cells would be useful. But still, we know that a lot of people have spent batteries especially coming out hybernation/from storage. Please send them to Rich.
2017-10-10
RichJ53
DTK Posted at 2017-10-10 19:20
True Green, sent me some from his swelled up batteries. Thank you very much TG.
PS. yes the other side of this cable from the battery can be cut down (removing the 2 temp sensor contact wires) and it will work on a harness...
It is nice to see the community friendship on this forum!
Thanks DTK
Rich
2017-10-11
fansa84fe8a4
Flight distance : 3 ft
There's enough people out there with dead Phantom batteries too, maybe even more than the Inspires.  Maybe the idea needs to be universal for all these DJI things, but how?
2017-10-11
RichJ53
fansa84fe8a4 Posted at 2017-10-11 07:36
Hi
Actually the Phantom battery would not be of any use in this case, because they are using a 3 or 4 cell type system. The Inspire uses a 6 cell battery and can be taken apart without breaking the pieces. The key component is the socket connector used to read the 6 cells that are soldered to the top circuit board.
But you are right, I am sure a lot of people have tossed out the Inspire 1 TB 47 or 48 batteries.  Sure would be nice to have all those socket connectors
Rich
edit: add photo
2017-10-12
DTK
Guys, please only send the cable and don't send the battery.
2017-10-12
Mark Guille
Flight distance : 2031818 ft
Jersey
I got mine, it works a treat, I couldn't be happier, thanks Rich. Unfortunately, I have run out of batteries that need balancing, so back in the draw til next time.
Mark G.
2017-10-29
RichJ53
Mark Guille Posted at 2017-10-29 03:22
[view_image]
Hi Mark,  great news and thanks for updating us on fixing your battery project. The nice thing is, when you need to fix a battery.... you can do it with the harness anytime you need to... You can cycle the batteries using the Li Po charger discharge program and then slowly charge them back up. Could add some life to your batteries.
The sad thing for me is the proprietary socket connector is hard to come by. My supplier has dropped my request for small quantity production of 150 pieces     so that is killing my production ideas of the harness for other I1 owners.
Rich
2017-10-29
RichJ53
Finally posting the video regarding this information and definitely not a great job, but something to watch on the subject.
Rich
2018-1-3
fansf9610274
I have a tb48 with one charge on it and cell #5 is low. I took off the top and seen the mini 6s plug and cursed Dji lol.I have chargers but need that plug if anyone has a plug or a donor battery let me know.My other batteries are new or almost new so no donors there.
2018-2-5
TruGreen
Flight distance : 621909 ft
RichJ53 Posted at 2017-10-29 19:36
i have two more plugs. purchased some used TB48 from a seller on Ebay. well i was sent two dead Tb47. filed a claim, got a full refund and was told to keep the batteries. well they do me no good and are also swelled slightly
2018-2-5
RichJ53
TruGreen Posted at 2018-2-5 17:48
Hi TG,
Were you thinking about sending me the plugs? You have my information and just send the cheapest way snail mail.
I have 2 of the JST-XH connectors on hand right now.     I see fansf96.... needs a harness
Let me know what you are thinking.
PS, I have not found any suppliers that would provide 100- 150 connectors and wiring pins for my harness idea. It has been really slow going.
Edit: I would be happy to send you some reimbursement for your help
Rich
2018-2-5
RichJ53
fansf9610274 Posted at 2018-2-5 17:31
TG posted he has a couple from bad batteries.  So I am not sure if you are looking for a completed harness... or want to do all this yourself?
Let us know.  If TG sends me the battery jumper wires and will be able to assemble 2 harnesses.  PM me for details.
Rich
2018-2-5
TruGreen
RichJ53 Posted at 2018-2-5 20:44
Hi TG,
yea ill drop em in the mail tomorrow
2018-2-6
djiuser_g6H44OFUYWIL
Are you still making the harnesses, I am interested in one. I have 4 TB48’s with screwed up cell voltages
2018-2-6
RichJ53
TruGreen Posted at 2018-2-6 16:57
TG
Thank you sir!!   sounds like you have been busy picking up stuff from EBay
All the best
Rich
2018-2-6
RichJ53
djiuser_g6H44OFUYWIL Posted at 2018-2-6 17:38
I have 2 guys ahead of you, but neither one has contacted yet.... So, you can send me your email by PM and I will see what I can do.  TG will be sending the sockets for 2 more harnesses.
These are hand made at this point waiting for some supplier to come through for me.
Rich
2018-2-6
RichJ53 Posted at 2018-2-6 21:04
Sent a PM
2018-2-6
TruGreen
RichJ53 Posted at 2018-2-6 21:00
TG
yea always searching ebay for good deals. sadly got screwed on the batts. should have been two good working TB48, but instead was sent to dead swollen TB47..... like really the add was pictured and described 48s, but got these in the mail.... ya i was not happy
2018-2-7
RichJ53
TruGreen Posted at 2018-2-7 06:34
[view_image]
I do not understand why people try this on EBay? Do they think that customers will not notice?  Glad you got this sorted out.
Thanks again
Rich
2018-2-7
TruGreen
RichJ53 Posted at 2018-2-7 17:59
Thanks again
the plugs are on the way though should have them next couple of days
2018-2-7
RichJ53
TruGreen Posted at 2018-2-7 18:06
Thank you
PS I am still looking for a home for the new Inspire 1 V2 combo kit (backup unit)  FW is AC 1.8 RC 1.6  let me know if you hear anything
Rich
2018-2-7
RichJ53
TG
Received  Thank you again!
Rich
2018-2-13
RichJ53
If you voted that you would like one of these harnesses...  I have 2 sockets from TG
So send me a PM I will give you instructions,  first come first serve
Rich
2018-2-13
TruGreen
RichJ53 Posted at 2018-2-13 17:29
TG
Rich
good to hear, and your welcome
2018-2-13
RichJ53
We have another Inspire 1 user that is trying to fix his battery using the harness. He purchased one of the Venom
Link to charger
but cannot get it to start the balance mode. I thought that you own a Venom charger you might have some ideas how to get the charger to read the cells or start up. I know that you can fool the charger by using another battery chemistry and disconnecting the port connector, but safety is first in my mind.
Thanks for helping
Rich
photo off set up
2018-2-16
RichJ53
[view_image]
Hi Mark, do you have any ideas regarding post #72?
Let me know what you think
Rich
2018-2-22
RichJ53
Do you have any updates regarding my post #72?
let us know if you need more help
Rich
2018-2-22
rg155
RichJ53 Posted at 2018-2-22 21:57
Haven’t had time to try yet but still no dice with it.
2018-2-23
RichJ53
rg155 Posted at 2018-2-23 09:09
RG,
Sorry to hear this. We will figure it out together. As discussed, it is very possible the one cell is low enough that this charger kicks a safety message. Sorry I do not have first hand experience with your charger.
Safety first, but you can change the battery chemistry to  LIION disconnect the balance port (special harness) then select the voltage to 22-24V    This would be (2.4v x 10 cell LIION)
Now because you do not have the cells being monitored with the balance port use a very low current level. (it will take more time)  use 0.2 amp . start the battery charge for about 10 - 15 min and stop. Go back to LiPo charge/balance with the harness connected again and see if the battery pack voltage is high enough to work.
Please be very careful and let us know
Rich
2018-2-23
RichJ53
RG
Per my email
please carefully try NiMH settings on your charger: I wanted to share this with others too
Can you please try using NiMH at 0.1 – 0.20 Amps  with the balance port removed and watch the pack voltage increase.  Do this about 5 – 10 minutes .  6 cells up to about 3.3v per cell minimum and 22.2 volts on the pack total. Then check to see if you can begin the normal charge or balance with the harness connected and selected to 6 cell LiPo
Remember to take care and be safe using these alternate methods of charging because the battery can start on fire if you do watch this very closely. All you are doing is topping up the battery just enough for the normal balance or charge mode will work.
remember that videos are only used for reference
Similar video
Similar video, but they are using NiCd
another example
2018-2-26
Mark Guille
Jersey
RichJ53 Posted at 2018-2-22 21:53
I'm guessing you need to lose the crocodile clips and just use the harness.
Let me know how this works out
Mark G.
2018-3-7
RichJ53
Mark Guille Posted at 2018-3-7 11:23
Hi Mark
I received the batteries for inspection. Inspire 1 TB48's  Unfortunately they have many if not all cells dead. I have not been able to get the dead cells to take any power (using special tools)
Looks like these are going to the garbage
The first screenshot is a Inspire 2 battery that has three cells low and the other two showing the Inspire 1 TB 48's
Rich
2018-3-7
Mark Guille
Jersey
RichJ53 Posted at 2018-3-7 21:00
Hi Mark
Hiya Rich,
If the cells have been reading 0.0 V for any length of time, I would forget about them, maybe donor the good ones.
Mark G.
2018-3-8
1234Next >
