When I start a recording, after an amount of time, the recording stops itself. That goes in 7 steps:
First, I can see 'No Signal' in the DJI GO app.
Second, the fans stop working.
Third, the gimbal moves in an unexpected way.
Fourth, the recording stops.
Fifth, fans start working again
Sixth, 'No Signal' is gone
Seventh, I can start the recording again
How can I solve this?
There are also some other things that I notice, but I don't know whether it has to do with this problem. those things are difficult to explain, so I made a video make it clear.
There are several threads regarding this already. DJI Thor says the issue has been recognised by the engineers and they are working on a resolution. Fingers crossed it's timely.
DJI Susan Posted at 2017-8-18 23:38
Does the issue appear recently? Do you use the original SD card? Please confirm so that I would check with our engineers the exact status.
Sorry for my late response, I was on holiday
Yes, it started a few days before my first post.
I'm not using the original SD-Card, but a Samsung Pro Plus MicroSDXC UHS-I Card.
I knew solution wasn't the best word to use, but I'm just happy that I don't have to send it in . For now, 24 FPS will be good enough, but I hope indeed that DJI comes with a firmware update soon to solve this issue. Are they usually fast when it comes to such updates? Will it be a matter of weeks or months?
Erwin1411 Posted at 2017-8-30 13:40
Cheers
There are several threads around this within the forums. Positively, DJI Thor says this is now a recognised issue and is with the engineers. I wouldn't be expecting a fast resolution, then if it comes quickly, it'll be a nice surprise.
Cheers
Our engineers are aware of this issue and they will try to fix it in the next update. Appreciate your patience.
I have the same problem while I'm flying after just 2/3 minutes stops
signal loss (300-500 meters away)
recording recording block
black screen
reboot
without registration ...?
are in open country without interference and .....
Report:
radio interference
passed 200 meters to 60 meters of signal loss cookie ....
what happens??
since you went to go 4 I've been risking two three times losing the phtantom
I can not get away a bit that ...... help .....
what do you have to do ....?
i would like to rewrite the original firmware just bought it was perfect .... now it's scary ....
