Charging Spark battery without quad itself!
8761 16 2017-8-18
Koshen_Bz
Flight distance : 11877 ft
Ukraine
Hi there!
Is there any way to charge Spark battery outside the drone itself using powerbank or car charger?
Lets look at situation, I have 3 batteries, I have hub and I can charge them together in one time, but only at home or with car invertor. So here I am, at the street, flying my Spark and one battery is dischared, what can I do? Discharge other two batteries and go home? Or set my self in the car and wait for charge? Or connect my drone to powerbank and wait for charge?
I think we need kind of adapter witch allow to connect battery to powerbank just via simple USB cable.
Did somebody find dat on Aliexpress?
Thanks!
2017-8-18
Dirk52
Flight distance : 232995 ft
Something like this:
https://de.aliexpress.com/item/H ... siteDetail2pcDetail
2017-8-18
Koshen_Bz
Ukraine
Dirk52 Posted at 2017-8-18 00:30
https://de.aliexpress.com/item/High-Quality-Rcharlance-5V-3A-Android-Plug-Charger-Converte-Charging-For-DJI-SPARK-Toys-Wholesale/32824253592.html?trace=msiteDetail2pcDetail
You are awesome dude!
But that thing look not so good, two cables, one adapter.
Why DJI doesn't produce dat type of accessories, just cable USB - Battery for 29.99
2017-8-18
fans5d9349b7
Does anyone have a pinout for the Spark battery so I make a similar device?
2017-8-18
Dirk52
Koshen_Bz Posted at 2017-8-18 00:28
Because you need a voltage of 13.05V to charge the battery.
This is why you need a StepUp converter from USB 5V. Only a cable won't work.
This adapter will do the job.. plug your powerbank into to converter and the battery into to converter.
2017-8-18
Koshen_Bz
Ukraine
Dirk52 Posted at 2017-8-18 00:33
Yes-yes, I understood, I'm saying just about how it looks like. Maybe we should wait for our China friend and there will be more accessories. It can be solid cable where converter is built in fat USB, so we will have ONE piece not three separate details.
What about 12V, a lot of powerbanks can give 12V/1.5A output.
2017-8-18
fans5d9349b7
When using the DJI charger to the spark, it outputs at 8 volts. My powerbank charges the Spark at 5v. Does this mean the Spark itself has a boost converter itself to charge its battery higher than 8v or 5v?
2017-8-18
Dirk52
fans5d9349b7 Posted at 2017-8-18 00:43
Yes, the spark has a build in step up. This is the reason why the sparks gets so hot when charging:
2017-8-18
Dirk52
Koshen_Bz Posted at 2017-8-18 00:42
Yes, a nicer packaging would be possible.
The spark supports QuickCharge3.0. So you can charge it with 12V and 18W.
But only when the battery is in the spark. When you charge the battery only you need 13.05V.
2017-8-18
Koshen_Bz
Ukraine
Dirk52 Posted at 2017-8-18 01:03
Thanks for explanation!
So, will wait for accessories, cos now there is no way to charge battery outside. The way to buy converter for car to make 220v, take hub and all cables to your vehicle is a little bit weird. And your car can't be always nearby
How about to buy second spark as charging station?
2017-8-18
Hankmeister
Flight distance : 19465 ft
same item from amazon   https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1
2017-8-18
fansa7ca743a
I have replied on another post:
https://forum.dji.com/thread-109341-1-1.html
It take longer time to fully charge a battery, and it is quite hot when charging in progress.
2017-9-9
fansa7ca743a
And you need power bank that support QC3.0 with 5V3A output
2017-9-9
Pashi
Flight distance : 4862598 ft
Russia
I don't know why DJI adds microusb to it's charging hub but you can't charge batteries via it...
2017-9-9
Tom_A
Flight distance : 899951 ft
What about something like this: https://www.amazon.com/dp/B01N4H ... _encoding=UTF8&th=1
This would charge more than one battery at a time if used with the charger that comes with the fly more package.
2017-9-9
WickedWingman
I come from the home built, hobby grade drones. We just use a lager Lipo to field charge our smaller ones. With a balance charger of course. There's probably a way to rig this up
2017-9-10
lannes
Flight distance : 4465 ft
I use this option
Omni Charge 20 - https://www.omnicharge.co/products/omni-20
Being in Australia , I have the international version
It gives 3-4 charges of a Spark battery which are a 17 wh capacity
2017-9-10
