heliman
Denmark
I can’t find the version information.
DJISimulator-UI has no about tab (an Apple standard).
It calls itself "DJI Assistant 2".
It’s has an about tab, called “About Electron”, which only says “DJIBrowser”.
So, I have just downloaded a fresh one from dji web site, which calls it 1.1.6.
Simulator still not working, and nothing telling me why.
In this version, the about tab is totally missing, but I found the version number 1.1.6 at the bottom right of the primary assistant window.
I connect the spark via usb to the mac and switch spark and rc transmitter on.
The assistant finds the spark and I start the simulator, and the transmitter LED goes green. The simulated clouds in the sim windows move.
But no interaction with the spark, which is in the middle of the window and
appears to be stuck a few meters above the green ground.
I did not use a mobile device for this.
