Crank your Inspire1
1234Next >
8624 130 2015-3-28
dundee
Flight distance : 33550 ft
Thailand
Hi guys,
I just wanted to share this before i go into the field with my bird.
Ill be back on this forum 2th. april to reply on your questions or remarks.
Increase your flight time and most important of all.....fly safe
2015-3-28
dundee
Thailand
2015-3-28
kolbjornfla
Flight distance : 16076 ft
Norway
Good one!!!!
2015-3-28
stephenbrink62
Flight distance : 380522 ft
South Africa
Ok..so that's what the key is used for....... . How does this increase the flight time? Does the battery power get released slower to allow the extra 160sec?
2015-3-28
Dave E
Flight distance : 729560 ft
Dundee you're an evil man lol
2015-3-29
garethgr
Flight distance : 366201 ft
Lol, that's awesome!
2015-3-29
markaguille
Flight distance : 2031818 ft
Guernsey
I actually just looked for the screw... couldn't find it
2015-3-29
Dave E
I have the new C version and the screw is on the front cowling not on the back.
2015-3-29
dundee
Thailand
stephenbrink62@ Posted at 2015-3-29 15:54
Ok..so that's what the key is used for....... . How does this increase the flight time? Does the b ...
You put tension on the build in spring by turning CW (Clock Wise)
Theoretically it could fly without battery with enough tension on the spring.
But don't go over 180 as the spring can snap. (Read the warning)
2015-3-29
dundee
Thailand
Dave E Posted at 2015-3-29 16:50
Can you post a picture of your back please?
Maybe you have an issue
2015-3-29
Dave E
I have many issues but I am hoping they will be addressed in the next life or maybe in the next firmware update!
2015-3-29
dundee
Thailand
Dave E Posted at 2015-3-29 17:03
I have many issues but I am hoping they will be addressed in the next life or maybe in the next firm ...
Hi Dave,
Don't be fooled. Keep the spirit up, as i do with this thread.
Cranking the Inspire1 is mechanical, so no firmware needed. No updates !
Maybe a more stronger spring to crank up would be nice.
Cranking up is like using a TB49. (Extra flight time  TB47 versus TB48)
2015-3-29
Dave E
I test flew the new C version yesterday and got a 26 minute flight from the TB47. I think its the new variable pitch props on the E900 motors. I reckon when I crank it up too it will be closer to 30 minutes. Great camera angles too when flipped inverted.
2015-3-29
kolbjornfla
Norway
I`v got a secret picture of the upcoming rescue pod!!!!!!!!!
It is said to be automaticly released in case of flyaways. It is named Inspire 0.1, and will be delivered
togeather with the new free props upgrade.
It will have return to home automaticly and contain your flightlogs. Way to go DJI!!!!!!!!!
2015-3-29
dundee
Thailand
Dave E Posted at 2015-3-29 17:27
I test flew the new C version yesterday and got a 26 minute flight from the TB47. I think its the ne ...
Very intresting Dave, clever move.
If you inlist into the beta-testing program, i give you some more feedbacks on the cranking.
Please keep this forum posted on how much flytime you achieve flying these variable pitch props after cranking. I remember now: acronym for these props is VPP or am i missing something
2015-3-29
Ph02on
Flight distance : 75673 ft
Perhape I have the C version too, as My screw only will only Wind-Up.  I am not going to force it, in case I spoil things.
Cheers
Jason
2015-3-29
dundee
Thailand
markaguille Posted at 2015-3-29 16:44
Please don't hate me for this
2015-3-29
rodger
Flight distance : 20145135 ft
Thanks for the info. Now I know why I received a chuckle from you the other day.
2015-3-29
dundee
Thailand
Ph02on Posted at 2015-3-29 19:17
Perhape I have the C version too, as My screw only will only Wind-Up.  I am not going to force it, i ...
Hi Ph.., hope you crank the big screw in the back and not the small one on the bottom.
2015-3-29
rodger
What are the differences between the C and the original? Is there a designation  some where to tell you what version you have?
2015-3-29
dundee
Thailand
rodger Posted at 2015-3-29 19:23
What are the differences between the C and the original? Is there a designation  some where to tel ...
I'm sure Dave will answer you on that.
2015-3-29
Ph02on
Thanks Dundee. I hear you
Cheers
Jason
2015-3-29
markaguille
Guernsey
All I could find was this.
Is this the same sort of thing?
2015-3-29
dundee
Thailand
markaguille Posted at 2015-3-29 19:29
Don't use that rubber thing !!!!
The (stock) screwdriver/cranker was delivered together with your Inspire1. (see pic above)
2015-3-29
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
How do i know the version i have? My inspire does not have the crank button, did they changed? Im flying aprox 20 mins with the TB48...
2015-3-29
dundee
Thailand
leoamartinez@gm Posted at 2015-3-29 19:40
How do i know the version i have? My inspire does not have the crank button, did they changed? Im fl ...
Hi leoamartinez,
All versions A,B and as of april first also C, come with the crank screw located in/on the back of the Inspire1.
Do you have the crank tool (see pic above)
2015-3-29
pidetectives
Flight distance : 2131073 ft
Wow Sorry but I am lost. What is this for again?
2015-3-29
dundee
Thailand
pidetectives@ya Posted at 2015-3-29 20:47
It's for cranking up the Inspire1
2015-3-29
w1der
Sweden
RAOTFLMFAO ...
2015-3-29
panox
Flight distance : 568819 ft
"Ich schmeiß mich weg!"  (I through myself away...)
2015-3-29
dundee
Thailand
Realy cranky no ?
2015-3-29
Dave E
Mark whatever you do, don't remove that tape holding the cranking band on cos you'll void your warranty.
2015-3-29
Dave E
You can tell if you have the new "C" designation by the variable pitch propellors and the new motors. There is also a modification to the front 2 foofoo valves for better airflow. Don't swap them to the back as the bird will lose orientation and may fly away!!!
2015-3-29
Dave E
kolbjornfla Posted at 2015-3-29 18:17
It is said to be automaticly released i ...
I really hope they change the colour of the rescue pod in the production models!!
2015-3-29
Dave E
Dundee, I think that I read on one of your earlier posts that you have a background in programming? I am just wondering with your experience, what have you set the low cranking warning percentage to on the app??
2015-3-29
kolbjornfla
Norway
Dave E Posted at 2015-3-29 21:48
My informant at the factory says the color of the rescuepod was deliberately done this way to avoid any suspicion during the testflights. It will however come in matching color to the Mothership when delivered.
2015-3-29
vonbaron1
Flight distance : 42014 ft
       That stir's the pot up.
2015-3-29
Tahoe_Ed
Flight distance : 2605 ft
I would not recommend that you play with the motor angle.  These motors are adjusted to a precise setting +/- .5 degrees.  While you may increase flight times you may also be sacrificing flight characteristics and stability.  You are also placing additional stress on the worm drive which could lead to premature failure.
2015-3-29
rodger
Dave E Posted at 2015-3-29 21:35
You can tell if you have the new "C" designation by the variable pitch propellors and the new motors ...
They changed the flux capacitor too.
2015-3-29
rodger
dundee Posted at 2015-3-29 19:27
Got it my friend, have a nice trip in the field and watch out for the large Kangaroos!
2015-3-29
1234Next >
