OneMatt
Flight distance : 155984 ft
GO4 is a terrible hog, and the reason for it is heavy radio use on mobile phones. If you don't force kill the app, it will near constantly poll for NFZ updates in the background. This is what is killing the battery.
Interim Solution (because DJI, fix you stuff): If you are on Android Nougat or later, use Data Saver. This limits background data access to 2 process (usually 2 most recent apps). If that isn't good enough for you, or you are on an older version of Android, download an app called Doze. It does the same things as Data Saver, but allows you to select which apps are OK to use background data. Obviously, don't choose GO4, and you will see significant gains. |
