lannes
Flight distance : 4465 ft
If he is using windows 10 , this has a "driver signature enforcement function that prevents loading drivers that are not digitally assigned.
I had the same reboot problem when calibrating my mavic vision system, apparently the vision drivers are not digitally assigned and cannot be loaded, hence the apps asks for the AC to be rebooted.
You need to turn off the windows 10 driver signature enforcement by following "solution 1" on this link. once you go through this process and the computer restarts you should be able to run the vision calibration.
http://windowsreport.com/driver-signature-enforcement-windows-10/
Please note the turning off of the driver signature enforcement is temporary so when you reboot the pc, it will be reset and you won't be able to do the vision calibration again, you will need to turn it off each time you want to it. |
