Aardvark
Flight distance : 384432 ft
Not sure if that is quite the right reset you've used there, try :-
To reset the RC
* Turn on the controller, the aircraft should be off.
* Press C1, C2 (The two buttons on back of RC), and shutter (top right button nearest antenna) on the controller and hold for about 2 seconds or so until it beeps (D-DDD), then turn the controller off.
* Turn on both the aircraft and the controller and link the remote if needed.
And if a good wifi to display device then V1.8 should be there as an option to download.
Could it just be a calibration needed after update ?
Edit :- you'll probably need to update RC to V1.9.2 to work with latest firmware update, that can be done through the aircraft status menu with display & good wifi connection.
