Micro USB Plastic Cover
1603 3 2017-8-21
Skyhawk991
Flight distance : 2113 ft
I have had my Mavic Pro for just over a week and have found the two covers on each side of the aircraft difficult to slide off as it is so tight but now one of the small plastic legs on the Micro USB cover aircraft has broken off. It looked like it was already fractured based on the visible white stress line.
Given how difficult the cover is to remove is it secured to the body of the aircraft by those small "clips" or is it another clip which is on the flexible peice of plastic that disappears inside and stops the cover from being completely removed?
Anyone know where I can get a replacement here in the UK as it seems overkill to send it in for a repair when all that needs replacing is this very small plastic cover
2017-8-21
We are sorry for the experience with our product, you can check more recommended repair center via the link below to see if they can help you. If not, please contact our support to start a ticket and send it in for repair, thanks.
http://www.dji.com/service/repair/centers
2017-8-21
BigBangGroup
Flight distance : 14278 ft
Did you ever get a good answer on this?
2018-7-11
PS013
Flight distance : 3579409 ft
BigBangGroup Posted at 2018-7-11 06:57
https://www.ebay.com/itm/DJI-Mav ... atinum/253528769620
2018-7-11
