WilfredFireStee
Flight distance : 182215 ft
Argentina
RoyTeo Posted at 2017-8-23 02:47
I had the same issues as you. i tried multiple OTG adapters, i also tried multiple micro usb to usb c converters, all couldn't work on my S8. Until i decided to use everything that came from Samsung. I used the samsung micro usb cable, used the microusb to usb c converter that came with the S8 an i used a S7 Microusb OTG...and this worked!!
Since the S8 OTG converter is a USBC, this won't plug into the controller, that's why i used the S7 OTG which is micro USB.
Another thing you can try is to use your own OTG to the controller but use the samsung USB C cable, or a mocro usb cable WITh the samsun converter..
Glad you feel my pain and i'm not just being a tool...... Much appreciated for the reply and the info. I am going to try the original samsung cables this weekend so i'll let you know how things went. |
