Dronie, Helix, Rocket after update to v1.006
943 3 2017-8-21
Hummingbird.UAV
Flight distance : 27489951 ft
Tested Quickshot modes, all worked.  I could set range for each and Spark returned after flying the manuver.
To set the distance follow this sequence.  Once airbourne select Quickshot and draw a box on the subject. Then select quickshot type.  Press that quickshot again and a slider opens at the bottom of the screen where the distance can be adjusted.  Then press the GO in the selection square.  Do not press the arrow at the left of the slider.  I found this reset the distance to MAX.  The dronie could use a bit more altitude gain but it is better than before. (using iOS with controller)
2017-8-21
Visualkaos
Flight distance : 755988 ft
Im very pleased with the update.  Its great to have Dronie working properly.
2017-8-21
Montfrooij
Flight distance : 2560453 ft
Good to know they fixed that issue!
2017-8-21
DJI Thor
Flight distance : 13602 ft
Thanks for the feedback. The latest firmware upgrading had optimized several performances of the drone and that also thanks to the users' previous feedback. Should you have any further questions, please feel free to contact us, we will do our best to help things out.
2017-8-21
