firmware update with Battery hub?..
14938 11 2017-8-21
Borae
Flight distance : 20151 ft
Hi Every spark pilots!
I do have battery charge hub and multple batteries. and I wondered how I can use micro usb port for firmware update.
However I plug in 3 batteries, power cable and usb cable to mac. and open DJI assi2 but nothing happen. so I unplug power and remove extra batteries. leave just one battery. again nothing happen.
Please share how to update battery firmware thru hub, if you do update thru battery charge hub.
Thanks,
2017-8-21
LOKY
Flight distance : 22359 ft
Is not possible, simple as that. Plug each battery on SPARK and do update, if issue, as I reported here on the 2nd, or 3rd battery , use the Assistant for the remaining batteries.
2017-8-21
DJI Thor
Flight distance : 13602 ft
The micro USB port on charging hub is for upgrading the hub's firmware but not the battery's firmware. Please mount the battery to the drone and then follow the on-screen instructions and the battery will be updated. Repeat these steps until all batteries are updated.
2017-8-21
dehner
Flight distance : 549931 ft
Philippines
Like to have a follow-up question on this hub.  I tried connecting the microusb port to my PC but DJI Assistant 2 cannot detect?  I tried powering it by plugging the hub to an outlet.  Same thing.  Main question is how to update the firmware?  using DJI assistant 2?
2017-9-21
Zbig
Flight distance : 7349 ft
Poland
dehner Posted at 2017-9-21 23:18
There's simply no battery charging hub firmware update at this point as there are apparently no known issues with the original one. The USB port is there just in case there's a need to update the hub in the future but it seems the software (PC-side) procedure is not in place right now. Nothing wrong with that.
2017-9-22
dehner
Philippines
Ok that solves it!  Thank you very much!
2017-9-22
DJI-Mark
The software needs to acknowledge your aircraft. If it is not, please reinstall the software and make sure you hook up the aircraft during the instillation process when prompted to.
2017-9-28
dehner
Philippines
DJI-Mark Posted at 2017-9-28 12:09
Thank you!
2017-10-4
djiuser_nkFXIz1
Flight distance : 31283 ft
Mexico
dehner Posted at 2017-9-22 17:13
So by connecting the spark, you were able to install the battery charging hub?
2018-1-1
sparkdrone
Flight distance : 9593 ft
You don't update the battery through the hub, you update it through the app on your phone.
2019-5-1
fansddcb9e8c
Singapore
Hello
Can anybody help me with Matrice 200. It power up but gives N/A error of battery in DJI GO 4 App and because of this it doesn't fly.
2020-6-2
fansddcb9e8c
Pakistan
Hello
2020-6-2
