Tombolian
Flight distance : 675958 ft
Panhead55 Posted at 2017-8-28 12:13
I updated yesterday to .1000 everything went fine no issues, firmware loaded pretty fast. Took it out for a test flight this AM and had an issue. Not sure if it is related to the new firmware or not so I thought I would put it out here and see if anyone else had the same issue.
I reset all values including checking my camera settings. I was flying in a spot that I fly all the time with my MP and have had ZERO issues at this location with interference etc. Today however, I received lost video transmission notification when only about 200 ft from my home point location. Could not get the camera to reinitialize in flight. Brought the bird back manually to home point. Rebooted everything including iPhone, controller, MP. Did it again on the second flight. Once again brought the MP home and rebooted everything. The third time the battery was low but I did not loose video transmission. I brought it home again changed battery and had no issues on the the second or third battery.
When you say you lose video transmission, is the app disconnecting from the mavic pro completely (as indicated by the 'connected' or 'disconnected' message at the top of the app), or are you losing video while the app stays connected? My mavic is constantly disconnecting from the app, but I think I've isolated the issue to the lightning port on my phone and the plug on the RC. If I don't touch the connection, it doesn't 'disconnect' from the app, but if I rest the palms of my hands on the plug (the natural position), it constantly disconnects/reconnects. Annoying to be sure, but not software related, at least not in my case. |
