Connor-UK
Flight distance : 202549 ft
Hi, i'm a fairly new spark owner, but waited a few km's to find these answers out.
- Is it true if you palm launch it doesn't record HD? I have read this on net but unsure as didn't once on mine and another time it did
- Is there a way to make the speed MPH but keep the rest i.e. distance and alt in Metres? as i'm in the UK and kinda mixed on imp and metric lol
- When recording the low res records sound, but when you download the HD version from the SD Card then you lose the sound, is there a way you can do this to have the sound on the HD version?
- Does sport mode use a lot more battery? its obvious it will use more, but as its double the speed, it doesn't seem to use double the battery.
- GPS accuracy, I find RTH never that good, example if I take off from a large balcony, it can try to land the other side of it, which is when I take over manually... is there a way or should I be a certain height before moving to get the most accurate GPS home signal?
Many thanks in advance for answering these questions.
