fans9ea9c44f
Flight distance : 22129 ft
It should work and I think it will, since it's a flagship feature. But it's also new for rc aircraft, and groundbreaking.
It's much better after FW upgrade, tracking is very good , now moving away if you approach it, and very fast to escape from. That's where it still needs work. If you run underneath it, it loses you which is fair enough. But I have not been able to re connect by gestures. It will land on flat battery, but at the end of a pier?
Can connect with rc quite quickly to retrieve, but will be great when/f DJI can sort that one.
Generally then much improved, but I have not yet succeeded with gesture for video. We all must gesture dfferently! I find the stills photo gesture 100% good! |
