lannes
Flight distance : 4465 ft
racer888 Posted at 2017-8-23 04:58
Are you shooting in manual mode? If you are what are you using for ISO, F Stop and shutter speed?
That picture looks like a really slow shutter speed which could cause the slight blur. Try pushing your ISO up to at least 400 (above 800 will introduce to much noise) and set your F-Stop to 5.6 (sweet spot) and then adjust your shutter speed to as fast as possible while still keeping the EV value to as close to "0" as possible, or even a little under or over in order to get a faster shutter speed. You may need to move the F-Stop around a little to get a good shutter speed, you may even be able to drop the ISO to 200.
+1 image is over exposed and there is camera shake from movement, I'd shoot F/5.6 and lower the exposure compensation to increase the shutter speed.
It's a bit difficult to take night shots from a drone as it's a moving platform and with a slow shutter speed that is going to cause blur, the gimbal can't compensate for a super slow shutter speed
This is from the DJI website, see the camera parameters PHANTOM 4 PRO 1/2s F2.8 ISO 100 EV 0.0
Fastest shutter speed to reduce camera shake as lens is wide open at f.2.8, ISO 100 to reduce digital noise
