Hello, my Phantom 4 is almost 10 months old and I have problems with dots and other errors in video when I shot in 3840x2160/30,24 or 4096x2160/30,24. I found some similar videos on the internet, but not the solution for this. Everything else is ok. It is the worse when I tilt gimbal up or down. Maybe the problem is caused by SD card. I have Sandisk Extreme 16GB MicroSDHC UHS-3 SD (the one that arrived with aircraft). Is it possible, that the card is causing problems? Thank you for your time.
https://www.dropbox.com/s/5afcfmpb12li76e/Untitled.MP4?dl=0
