Spark vs Wind Gusts
8607 11 2017-8-22
KSBV
Flight distance : 1104252 ft
Really wanted to fly a few batteries today after the update yesterday but it's simply too windy right now for a safe flight (winds at 100ft gusting to 35 mph).  But I do have a question for those that have experienced this - can the Spark handle gusts in excess of the top speed of sport mode?  Just wondering if there is enough spare motor power to still make progress into winds like this or if it would simply lose the battle.  I get that reducing altitude would help but this isn't always an option.
Note that I'm not planning on testing this.  Just want to have an idea of what to expect if I ever get into a situation where winds suddenly pick up.
Thanks!
2017-8-22
SeanGillian
Mexico
I flew off my 18th stories high, wind was pretty decent, don't know gust speed....little jittery with Spark and wind take it into a wall, drop like a brick from 18th stories high, damaged but still function, well build Spark, (lens cover, battery and body damaged,), start a case with Spark luckily I have DJI Refresh
2017-8-22
Oracle Miata
Flight distance : 3759829 ft
It's good up to 15mph gusts, but that's the upper end of what you want to fly it in.  It struggles at that point.
2017-8-22
KSBV
Oracle Miata Posted at 2017-8-22 16:09
I've flown it in an open field with winds like that and was really impressed with the stability.  It did get bumped around quite a bit but the video (of the trees swaying) remained excellent.
Thanks for the info!
2017-8-22
phatav8r60
China
Ha!! I flew with about 15-20mph sustained and stronger gust, in my video you see the Spark do 360 in less than a second as gust hit it.  Usually, you can face into the wind and work lower where there is a building or other obstacle to block the wind and land.
2017-8-22
phatav8r60
China
Ha!! I flew with about 15-20mph sustained and stronger gust, in my video you see the Spark do 360 in less than a second as gust hit it.  Usually, you can face into the wind and work lower where there is a building or other obstacle to block the wind and land.  But best idea is not to try and fly in a big wind.
2017-8-22
PascalG
Flight distance : 274327 ft
Down many flights in 15 mph sustained surface winds with higher gusts (triggering the high wind warning)  including  near cliffs which increase turbulence and  the spark was rock solid. 20mph sustained is as far as I m willing to go, 35mph isn't wise...
There is some reserve power as sports mode I have never noticed a top speed difference whether flying into or off the wind.
2017-8-23
fans9ea9c44f
Flight distance : 22129 ft
Check difference between ground speed and airspeed.35 mph airspeed into 35 mph windspeed will give 0 mph ground speed. Therefore it will appear to hover.
2017-8-23
Connor-UK
Flight distance : 202549 ft
I wouldn't fly over 15mph, my concern is when in sport mode more, when braking or going fast it could get a gust of wind which would flip it, guess if you were high enough you would reverse up and down and be able to fly upside down?
2017-8-23
STech - Hathder
Flight distance : 459094 ft
Brazil
Connor-UK Posted at 2017-8-23 14:45
If the drone Flip it will turn off motors and fall, and if the flip is realy fast, the drone will return to normal position ( theres a video on youtube showing this).
2017-8-23
KSBV
Thanks to all. I'll continue to go with 25 mph as theax that I'm willing to fly in. Good to know there is some margin left just in case.
2017-8-23
DJI Thor
Flight distance : 13602 ft
We don't recommend flying the drone with the wind exceeding 10 m/s. If a strong wind suddenly comes, it depends on the speed of the wind. The drone might be overwhelmed if it can not resist the wind. So please fly with caution.
2017-8-24
