TranceMist
Flight distance : 1661591 ft
DJI Thor Posted at 2017-8-24 18:07
Just to verify, you have never got Tapfly worked, right? Had you removed the thin film of the visual system? Or did you attempt to initiate Tapley when the drone directly faced the sun so the drone activated obstacle avoidance? Please help to confirm.
Thanks for the "are you an idiot newbie?" questions... I'm not. ;-)
I did finally get it to work, but not as I expect.
I do think it was failing to work due to too many contrasty shadows.
However, it also fails when I tap on a point in a field 100m away due to a line of trees 150m away that is clearly not in the way (nor where I taped).
In general I find that the obstacle avoidance system does not work with high contrast and shadows. :-/
When I did get it to work it did not work as I expected. In coordinate mode I expect it to fly towards those coordinates while I can control yaw (for camera angle). Yet as soon as I try to adjust yaw it just stops and hovers and complains that there is user control input. :-(
Is the Spark supposed to let me control yaw during a coordinate tap to fly flight?
Or is it only the Mavic that can do that? |
