rlx
Flight distance : 2244423 ft
Hi,
I just wanted to share my repair story. Sadly, it was much different than the last time I sent in a warranty repair. Little back story, I am not a new flyer and have been flying DJI drones since the P2. With a P3P, i was having problems with the aircraft disconnecting after very short ranges - usually about 100-300ft. I did all the usual. Updated the firmware, tried using it in open fields to rule out interference, same result. I swapped out the remote with another, same result.
Talking to DJI and they recommended I sent it in under warranty repair. I did this and when I received it back the box had no paperwork in it at all. Just a new controller in plastic. Previously, I had paperwork showing what was repaired/replaced. They even sent me photos of my drone last time when it was checked in. Naturally, I wanted to know what was repaired. I emailed support and they said they didn't have that information. I called the phone number and the man was very rude to me and kept saying "You got your drone back, it was repaired, so whats your question?". He didn't seem to understand that I have no way of knowing it was repaired and would like to know what was diagnosed. E-mail support also said they could find no information on what was repaired. At this point, I had not actually flown the drone but suspected it was not fixed because they included a new controller which was not the probem. I specifically noted the controller does not appear to be the issue since I have tested multiple controller. I did fly the drone last night and it has the exact same problem that I had before.
I am frustrated because I took a considerable amount of time to explain my issue. I also supplied flight data links and context to each flight. This apparently was all ignored and not only did they not fix the problem they did not even try to re-create it or test that the problem was fixed. I pulled the .DAT files off the drone to see if I could find out what was repaired and what kind of tests they ran. While there are other things to note, the main take away is at no time did they ever try to re-create the issue or test that the issue was resolved. The furthest it ever flew was 12meters. I get that they can usually diagnose issues without having to fly it because they have seen them all and likely know why things happen. But in this case, it would have been helpful for QA to test to make sure the issue was resolved.
I had assumed this drone would be prepared before I head out on a trip to Europe but now I am not too sure, especially now that I have to start the repair process all over again and just hope it will be prepared. I understand things happen and that's life, but it has caused me to lose confidence in DJI repair center as a result. I am hoping any repair or resolution to my problem can be escalated and expidited.
