hallmark007
Flight distance : 9827923 ft
Spaners Posted at 2017-8-25 10:19
When you calibrate the IMU (this is done for level) when you calibrate a compass it is for direction
once the imu is calibrated it should not need recalibrating again so long as it was done correctly in the first place, ie on a level surface and in the correct order, the key to imu calibration is to make sure the drone is completely still at each reference point. DO NOT hold the drone as you calibrate it, it must be placed on a level surface for all six reference checks.
Compass calibration is a separate thing. The key here is to be in an area with no magnetic, or electro magnetic interfearance. do your compass calibration in a big open space away from your mobile device and your RC (a good ten paces) Do not have change or other metallic objects in your pockets either. DO NOT do compass calibrations at home or in built up areas.
Ignore anyone who tells you not to calibrate your compass.
So first you are asking everyone to ignore their manual.
You live in the U.K. No matter where you go in the Uk there is almost no compass declination .
The declination at London, UK is one degree 7 minutes west (2014), and as the country is quite small that figure is fairly good for the whole of the country. It is reducing, and they reckon by 2050 this will be zero, so would you be advising those in the U.K. To calibrate there compass if say they move 50 miles and what would be your reason for this.
Yes maybe if your crossing the US there may be changes in declination i.e. the United States, for example, the declination varies from 16 degrees west in Maine, to 6 in Florida, to 0 degrees in Louisiana, to 4 degrees east (in Texas).
So telling people to ignore those who tell them not to calibrate compass is not the best advice, for those who calibrate what is a good compass if they get it wrong and something happens they crash. And dji tells them that they calibrated their compass wrong and warranty is void.
Most reported crashes and fly always begin with the same opening line, ( I just calibrated my compass and !!!!)
There is one thing we do know about calibration if your compass is good you can't make it better, I fly commercial for Uk company using dji Matrice anytime we get any compass warning whether it's to calibrate or move, we always move location.
So using declination for the need to calibrate you really should spell out distance and point out degrees of difference.
I will be moving 400 miles tomorrow to Islay in Scotland I know I won't need to calibrate anything.
Think you will find all dji drones are set up for the areas they are sent to. |
