Where Can I Get Replacement Landing Feet?
8696 19 2017-8-25
fansaeb28bba
Flight distance : 175600 ft
Switzerland
After a crash both front landing feet are bent and cracked, thankfully they can just be screwed off, but I can't find replacement feet anywhere.. Does anyone have a source? I don't want to spend a fortune and long delay to get repair by DJI and don't want to buy the whole motor arm assemblies because the arms and motors are fine.
2017-8-25
Gusmtb
Flight distance : 35249 ft
I'm amazed no company has started making third party replacements.  one of my mavic legs in broken so had to glue and gorilla tape it back in place because I couldn't get a simple replacement,
SalvageDrones have sold some official legs, but when I asked about them myself and many others have never gotten a reply from Salvage.
2017-8-25
fansaeb28bba
Switzerland
Gusmtb Posted at 2017-8-25 03:45
This probably will be Plan B, to glue the feet under tension..
2017-8-25
MARSAN
Flight distance : 966978 ft
Belgium
fansaeb28bba Posted at 2017-8-25 11:27
I don't know how badly those feet are damaged, but you could use a combination of glue and heat-shrink tubing.
Be careful though, as the Mavic's antennas are in these feet.
2017-8-25
Gusmtb
Yes careful not to glue the antenna.   I just used enough glue on the damaged part of the leg and then used the silver coloured gorilla tape cut to shape to hold the leg in place. Works a treat and is very strong.
2017-8-25
ImHereToCrash
Flight distance : 5381368 ft
i have a 3D printer and im a bit curious if it is easy to make replacement legs and just swap out the antenna? or is the antenna fixed inside the eg like laminated inside?
was thinking maybe making a boot  or as my GF calls them "bootsies" for the legs as protective means so that takes the impact not the actual legs
2017-8-25
Gusmtb
Antenna just had a small amount of soft glue near top, can be scrapped off and antenna lifts out. Also has a black deflector or shield thingy in the leg too.
2017-8-25
ImHereToCrash
Gusmtb Posted at 2017-8-25 17:39
awesome, ill dust off the 3D printer when im back at the farm and do some tests..
2017-8-25
We don't suggest to repair the drone by yourself because it may avoid the warranty, you can try to contact other recommended repair center which is closest to you if you don't want to send it in official repair center.
Please check more recommended repair center here: http://www.dji.com/service/repair/centers Thank you.
2017-8-25
fansaeb28bba
Switzerland
DJI Mindy Posted at 2017-8-25 18:56
Seriously. to unscrew 3 screws and refit a little plastic foot will void the guarantee? DJI needs to recognize that many drone flyers are tech savvy and should sell the complete range of spare parts to private customers. Currently, many vital parts are available over Ebay and DJI is missing out on this revenue stream.
And by the way, there doesn't appear to be a recommended repair center in my country.
2017-8-26
Gusmtb
Well anyone who could make a good 3D printed replacement would make a killing on eBay selling them. A proper replacement would be better though.
2017-8-26
fansb79afd5d
Right. You don't want to avoid the warranty.
2017-8-26
fansb79afd5d
ImHereToCrash Posted at 2017-8-25 16:53
I have a couple sets of these. They just slide on over the stock legs and have little "grippers" inside to hold them tight.  The rear gear attaches to the little metal tabs on the bottom. Really helps in longer grass and helps keep dust and debris away from the camera.
2017-8-26
R&L Aerial
Flight distance : 298100 ft
You can make them, if your handy enough. I had to make new landing feet, I used quarter inch square hard wood, epoxy and black paint...
2017-8-26
fansaeb28bba
Switzerland
fansb79afd5d Posted at 2017-8-26 13:03
I saw these on Aliexpress, but do they work if the stock feet are bent?
2017-8-27
fansaeb28bba
Switzerland
Ok, managed to fix the feet for now:
1) unscrew feet
2) hold the flat part in fingers and use pliers to force each foot back into the original angle
3) screw back on
4) use 2-component epoxy glue to fill up the cracks and strengthen the foot
5) let glue set with appropriate weights on the mavic.
2017-8-28
djiuser_3IgmlhvJyMCj
Should have done more reading before I spent money with DJI, If DJI is not going to sell parts for their products This will be the LAST DJI product I BUY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2018-2-6
scealux
Here's a link to a landing leg model I made. Might need a few tweaks to be perfect, but it's pretty solid so far. Hope that helps whoever has a 3D printer at least!
2018-5-29
fansaeb28bba
Switzerland
Wow, brilliant, thanks. It works!
In the meantime they're available on Ebay, search for "MAVIC FRONT ARM"
2018-6-5
fans57bc1b84
Hi, maybe if not to late I can help!  Have stock of both left and right replacement legs available. eBay 283107850084 and 283107850135. UK based.  Regards,  David
2018-9-9
