I am not a technical person. I just want to fly and shoot some video.
Have accumulated approx 10 hrs total flight time over the last year.
I have noticed that my P4 is very jerky when in flight. Not sure why.
Second, This newest update does not allow me to fly very far or high.
I really just want to be able to fly on demand. I have missed several opportunities to shoot some great events because software updates or other issues would not allow me to fly.
To address the second problem first: After your last firmware and software update, your height and distance are restricted until such time as you log in to your DJI account for verification, then all SHOULD be well. Also, make sure you have not left the craft in Beginner mode, which is the default setting after upgrade I believe
Maybe uninstall the DJI app on your device and reinstall it.
This would then force a sign in on your DJI account and at least you know you are fully up to date.
I had to discharge 3 batteries for air travel and must say. The P4 is flying very erratic. Almost uncontrollable.
Very upsetting and I must say, this is going to be brand damage for sure. I actually lost sight of it as it went behind some trees and went into auto return land mode and almost landed in the woods. Crazy.
DJI Diana Posted at 2017-8-27 20:43
Calibrate the IMU, make sure there are more than 10 satellites can be detected by the drone, then try to fly it in an open area, see if it is better.
Thank you. Just got back from a trip and it was very uncomfortable using the P4 but that was what I bought it for. I will calibrate it tomorrow and advise of the outcome.
fans26a47254 Posted at 2017-9-3 15:00
I did not get a chance to calibrate it yet. When I turned it on it made me comply with a controller update which I did. I was hoping that would have a fix. I just flew it and nope, very erratic and very noisy.
Update : Was able to resolve the height and distance restriction. I calibrated the compass and the IMU with 13 sats detected. Still is flying erratic and not very safe. If I take the Vps off it is more stable but has a good amount of drift.
C.Degan Posted at 2017-9-16 20:09
VPS shouldn't effect drift. As long as the Flight Mode Switch is in the P-mode or S-mode, GPS should be the only thing that controls the drift.
Also noticing every time I fly I am getting a cautionary high wind notification. There was no wind this morning when I flew.
So I have done everything listed above and what has been identified on other threads and the flight characteristics have not changed at all since the firmware update.
After all the time spent, my drone flies like garbage. It might even be worse now then yesterday. It was less than a year old when I installed the update. I get high wind warnings when there is no wind. It has never been dropped or damaged in any way. It is now useless as a UAS an I am pretty pretty upset. I have $1400 invested in the drone that took me a while to save up for and now many hours of wasted personal time. Enough is enough.
I have followed everything that has been suggested and have followed the instructions directly from DJI below.
From DJI :
Thank you for your response.
We are sorry to know that you are experiencing flight issues on your Phantom 4 after you upgrade it's firmware.
We do understand that you are concerned about the safety of your flight.
Rest assured that I will do my best, to be able to provide you the best and easiest troubleshooting steps for that.
To be able for me to do that, I'll just need to gather some information below.
Please provide a screenshot of the aircraft’s current firmware locate at the ABOUT page on your DJI Go App (Settings > General Settings > About).
Did you received any error message? If yes, may you send us a screenshot of that error message.
Did the unit crashed or dropped?
What is the troubleshooting steps that you already did?
I've attached some troubleshooting steps below.
Please calibrate the IMU first, and second the VPS.
IMU Calibration
1. Make sure that the Aircraft and Remote Controller battery is more than 50%.
2. Turn on Remote Controller and connect to the Mobile Device.
3. Place the Aircraft on a level surface.
4. Turn on the Aircraft.
5. Launch DJI Go app.
5. Go to Main Controller settings > Advanced Settings> Sensors> IMU Calibration> Start Calibration.
6. The calibration process will take about 5 minutes. Please wait for the confirmation on DJI Go app.
7. IMU Calibration will fail if the aircraft is not positioned according to the instruction on DJI GO app.
8. If calibration fails, restart the aircraft and calibrate the IMU again.
VPS Calibration
Note: Make sure before perform VPS Calibration Phantom 4 battery is sufficient and USB Cable is connected to a PC
1. Connect the aircraft to your PC with a USB cable
2. Launch the DJI Assistant 2
Select Phantom 4 and click calibration on the left side
*Note: Read the three steps carefully
First step: Hold the aircraft and point the nose towards the screen.
Second step: Aim for the on screen boxes as inscructed
Third step: Complete both horizontal and vertical calibration
3. Please begin the calibration
Point the forward facing obstacle sensors towards the screen and calibrate them.
Position the AC such that the corner of the red box coincide with the corners of the blue boxes
And wait a few seconds the AC should now stay in this position for the rest of calibration.
Please do not move it arbitrarily tilt the AC up and down to fill the vertical progress bar
When the vertical bar is illed tilt the AC left and right to fill the Horizontal progress
When front facing obstacle sensor calibration is complete
4. Now Calibrate the bottom sensor
Now face the bottom of the AC towards the screen the battery compartment should point to the right
And the nose should point to the left
Now Calibrate the bottom cameras with the bottom of the AC facing towards the screen position the AC
Such that the corners of the red boxes coincide with the corners of the blue boxes and then wait for a seconds
The AC should stay in this position for the rest of calibration Please do not move it arbitrarily
Tilt the AC up and down to fill the vertical progress bar
5. When you finished the software will automatically calculate and apply the calibration settings
Please ensure the Phanto 4 battery is sufficient and the data cable is connected to the PC
After the calibration is successful please click finish
If you find challenges on the provided steps above, you may watch our video tutorial on Youtube:
Please let us know if the troubleshooting steps above didn't solved the issue.
Thank you for choosing DJI.
If you have other concern don't hesitate to contact us.
C.Degan Posted at 2017-9-21 03:42
If it is a P4 I would suggest rolling your firmware back, you will find the instructions and references in the post that was shared in a link above.
Pretty upset, Here is my repair quote. Be reminded, that this drone has be kept in its case and has been very well taken care of. There should be no reason for any hardware malfunction or damage.
Case No: CAS-1028547-Y3P2Z6
DJI Care Balance:
Quote Date: 10-11-17
Remarks: Dear Customer, Unfortunately, damage that is not caused by a product malfunction or is out of the warranty period is not covered by DJI aftersales policy. We'll either repair it or replace it with a product that's new or equivalent to new in both performance and reliability after payment has been received. For more information, please visit http://www.dji.com/service/policy DJI North America
Item Quantity Unit Price(USD) Total Price(USD)
Phantom 4 Right Landing Gear Module 1 10.00 10.00
Phantom4 Camera Main Board V04 1 176.00 176.00
Repair Service Fee 2 65.00/H 130.00
Freight: 0.00
Total Amount: 316.00
DJI Care deduction: 0.00
Total Payment: 316.00
