Donnie *
Flight distance : 3636782 ft
Cliff1858 Posted at 2017-8-30 14:28
I've done everything for a proper firmware upgrade. Format on AC, proper firmware, RC not on, etc. Very frustrationg as I need it for a shoot this week and feel I will need to send it in.
Just to confirm , you are uing the X5 camera to load the FW is that correct ?
If you have not done so , format the SD card on the Aircraft and then load the BIN file to computer and then load ONLY the BIN file . ( just re read that you are doing that , sorry )
I have seen many times where a MAC did not format the SD card correctly causing issue OR it does not just load the BIN file and there is other data there as well.
*** Try another SD card as well .
try the PC if all else fails .
***According to the log , you are using the X5 firmware . So in that case you MUST use the X5 camera to load the FW
This is strange becaue you obviously know how to load the Fw as you have done it in the past with success .
Let me/Us know
donnie
