roof55NO
Norway
Well, what issue to use filters? Photos? No filter are needed. Video clips? yehh. especially when you use CAM without mechanic shooter, as all P3 series behavior. Look at P4 Pro. The spec are best you can obtain, bigger sensor-1", and mechanic shutter, vs P3 electronic shutter. What I'm talking about, the mechanical shutter; it only records light while the shutter is open and bleeds off charge when it is closed. Brilliant!
And P3 shutter; as light continuously hits the sensor, when the exposure is started, additional circuitry has to accumulate the number of photons captured (there is no light /dark of the mechanical shutter here) The amount of light in each photodetector is a counted during the exposure window. This circuitry is built into the photodetector, and this takes up space, reducing the overall area that can be used to capture photons; this in turn reduces sensitivity and requires more amplification, and it's means higher noise.
In other words, mechanic shooter "are you ND filter", and to avoid the effect "Rolling shutter eg. Jello effect", you need ND filter for electronics shutter, and versus P4 pro, no needed. An what are best ND filter? It becomes to your wallet, see at amazon/eBay approx 10 box, it's cheep, but it's destroyed your good frames quality. In my mention, got for SRP filter, Polar Pro. Not cheep, but it works!
