WernerD
Flight distance : 350837 ft
Austria
I think a lot of people here would appreciate if you could disclose the bluetooth commands the Ronin-M supports. If you are one of these, please post here to show your interest.
Especially if the commands would include absolute position commands like "look 10° left from center and 30° downwards from horizontal", I guess the demand for this gimbal would spike.
This would enable use to write various apps, so you can control the gimbal movements from a tablet, most importantly pre-program movements.
Use cases:
- A CableCam Controller moves the gimbal while driving on the rope in order to point to the same POI all the time but from different angles.
- Preprogram a movement to repeat the same multiple times, e.g. for a stationary rig or for overlays.
- Timelapse, where you want to pan the gimbal by 180° in 10 minutes.
- Tracking of an object.
- Gigapixel Panoramas
- Ronin is on a crane and depending on the pan of the crane, the tilt is adjusted by the app automatically to ease up the Follow operation - just one axis needs to be controlled manually.
- Simple Astro-Tracking applications.
All of that can be enabled at once if only the firmware would support that - if it doesn't already - and you explain how to connect to the bluetooth module executing such commands.
A whole new world of opportunities and use cases for the Ronin at virtually no costs.
