Indoor Height Limit?
8922 33 2017-8-26
Boernietiger
Flight distance : 194875 ft
Is there an indoor height limit at the Spark?
I have flown in a high church, unfortunately there was about 8 m height the message  "limit reached" and i couldnt fly higher,
But I have to fly about 16-20 m high,
is it possible to override the limit somehow?
2017-8-26
Aerial Ant
Flight distance : 1249715 ft
Hi, as far as I know the only limit other than your country's maximum height limit is one you set in the DJI4 go app. Check to make sure you didn't accidentally change it.
2017-8-26
Dirk52
Flight distance : 232995 ft
When you are flying without gps only in opti mode there is a height limit.
2017-8-26
Montfrooij
Flight distance : 2560453 ft
That might be a bummer.
Why would they have that?
2017-8-26
fans78376957
Make sure that you are not in beginner mode or the height limit will be restricted
2017-8-26
Boernietiger
I was not in beginners mode and the outdoor limit was 100m,
I tried also to start from the balcony at the second floor,
Starting and ascend on the balcony was correct,
but when flying outside the balcony the Spark descended automatically to 6-8m above the lower floor,
Indoor was no Gps,
so I think, there is a limit at that height where the bottom sensors are working???
2017-8-27
Montfrooij
That might be the logic. No GPS = rely on bottom sensors = limiting height?
2017-8-27
DJI Susan
There is no GPS indoor, so the VPS will work. If you need to fly about 16-20 meters high, you may consider to disable the VPS, then the drone will enter ATTI mode. It requires high flying skills, I would recommend you to practice it in the outdoor first.
2017-9-3
Montfrooij
DJI Susan Posted at 2017-9-3 22:35
Good suggestion, would the absence of wind make ATTI flying more simple?
2017-9-3
fans34089405
Flight distance : 4862598 ft
Russia
It's impossible to fly in ATTI outdoors because we can't switch to ATTI mode on Spark((( So we can only turn off VPS and fly indoors but not higher than 30m...
2017-9-4
Boernietiger
THX
I will find a place indoor for practice
2017-9-6
LOKY
Flight distance : 22359 ft
Only a matter of curiosity, who would fly a drone inside a Church?
2017-9-6
Sparky_17
Flight distance : 62349 ft
LOKY Posted at 2017-9-6 09:42
I had the same thought.  But I'm glad there is a max height when flying indoors or in ATTI mode.
2017-9-6
Boernietiger
Sparky_17 Posted at 2017-9-6 09:48
See it here
2017-9-6
LOKY
Boernietiger Posted at 2017-9-6 13:51
See it here
https://youtu.be/ysbGHwIusrs
Very Nice !
2017-9-6
ThirdEyeFlyin'
Flight distance : 162444 ft
How do you turn off vps?
2017-9-6
DJI Elektra
China
Please note that you can not turn off VPS.
2017-9-8
moh_rafiudeen
Flight distance : 328957 ft
Montfrooij Posted at 2017-9-3 23:52
there might not be wind, but might be a fan running or wind from A/C?
2017-9-8
Montfrooij
I can think of some very nice churches I would love to fly in and make some awesome footage.
2017-9-8
Montfrooij
See it here
Beautiful!
Maybe you can slow down on the pan's a bit. Not sure if you speed them up in post or just had fast motion with your Spark
2017-9-8
Boernietiger
Montfrooij Posted at 2017-9-8 03:07
Beautiful!
sorry  for the late replay
the indoor flight and the video are  only tests and the video is not ready at all,
the video shows the real speed, you are right ,
the pans are too fast - it was really exciting or fly there :-)
2017-9-9
hallmark007
Flight distance : 9827923 ft
Montfrooij Posted at 2017-8-26 10:35
Spark without gps indoors or outdoors is limited to 16ft as a precautionary measure, yes Atti mode without wind is somewhat easier to manage, but indoors gives you a much tighter space to work in and once you start moving spark you will continually need to be pushing sticks to control it , once you start creating propulsion you have to control this, you cannot disable VPS , so best option for flying indoors is perfect light good textured flooring fly in opti mode gps if you have it or if Aircraft goes between opti and gps . Set RTH to land or suitable height for environment this is crucial
2017-9-10
hallmark007
There is a max height when flying without gps indoors or outdoors, this is a precautionary measure, if you are flying indoors and have gps there is no height limit, when flying indoors always remember to set RTH to land or set height to whatever suits the environment you are flying in.
2017-9-10
Montfrooij
hallmark007 Posted at 2017-9-10 01:45
Yes, it will require lots of practicing and common sense I guess.
2017-9-10
Montfrooij
Boernietiger Posted at 2017-9-9 22:38
No problem, I can imagine
2017-9-10
Montfrooij
How to turn off VPS?
2017-9-16
hallmark007
You cannot disable VPS on spark.
2017-9-16
Montfrooij
hallmark007 Posted at 2017-9-16 10:12
Ok, a small mistake from Susan that is.
2017-9-16
DJI Susan
Sorry, my fault, I just forget we are talking of Spark. The Phantom series and Mavic are available to disable the downward VPS.
Hallmark007, thanks for correction.
2017-9-20
hallmark007
DJI Susan Posted at 2017-9-20 02:26
Your welcome DJI Susan, it was DJI Thor who pointed it out to me.
2017-9-20
Wachtberger
Flight distance : 261509 ft
Nevertheless this video demonstrates that the Spark can be a very useful tool for architects, contruction workers, renovators etc. Thus the ability to switch off VPS also on the Spark might be a future feature to be considered by DJI.
2017-9-20
Montfrooij
No problem, I have great admiration for your knowledge. So many things to remember
2017-9-20
Boernietiger
Wachtberger Posted at 2017-9-20 02:57
That's right, I'm an architect :-)
The possibility to switch off vps would be very useful for indoor inspections
2017-9-21
djiuser_kdhkNeNI6IKW
I've flown in a couple of churches to get photographs that would be difficult even with a ladder.
Looking at the stained glass windows and other such decorations that are 10m or more up, or I will be when I figure out how to get it to overcome it's fear of heights.
2021-4-24
