Charles Adams
Flight distance : 3821312 ft
Inspired by other forum conversations, I performed two RTH tests today. All equipment is on latest firmware and software.
First test: Using only gesture control (no phone no RC), I palm launched, sent the spark away to follow, and walked some distance from my launch location. The purpose of this test was to determine the behavior of the spark, when using only gesture control, when the batteries ran low.
Result: The LEDs performed their indication of low battery, and the craft then performed an RTH by elevating to altitude, flying back to the original palm launch location, and descending from there.
Conclusion: Current behavior (whether or not designed or intended) is that the spark considers the location of palm launch the RTH location. It does in fact elevate (and could therefore plow into above structures or obstacles).
Question: Is this the best behavior for this use case? I don't think so. I think it should assume that it is within 20 feet of RTH when in gesture mode, and descend in place.
Question: Does not compass and GPS have impact in this use case? (That's rhetorical). Could not environment factors impeed the behavior so much that the craft could be at risk? I need to review the manual and see if the led lights are indicating successful gps and compass operations. Otherwise anybody who chooses to fly with gestures in a man-made environment may be taking risks.
Second Test: Using phone and RC, I launched and set home point. I then walked and flew a great distance away, and I set home point to location of RC. I then insructed the craft to RTH. It behaved as though my current (RC) location was home point, and did not fly back to original home point. I then performed a second test. I set home point to craft location, I walked and flew some distance away, I set RC location to home point, I walked and flew away from that location (craft was in a separate location from myself and from any of the prior pre-set home points, and I was in a completely different location from craft or any other home-points). I instructed the craft to RTH, and it flew back to the most recently set RC homepoint location.
Conclusion: I couldn't get this RTH functionality to fail. It behaved as expected and desired in every instance.
