ImHereToCrash
Flight distance : 5381368 ft
daniel1111 Posted at 2017-8-27 12:05
Hey there, no worries about sounding mean and thanks for your response I calibrated the compass only for two reasons: Firstly upon booting up an error message concerning the compass occurred, which led me to do the calibration. Secondly, that boot up was after a huge change in location, from China to Switzerland (which at that time made me think it might have to do with the error that came up). I did not recalibrate the IMU.
Well, I hit return to home as last measure that I could come up with in that moment. Everything happened within a timeframe of about 20 seconds, from first becoming unresponsive and eratic to heading off into the woods with 35 km/h and a black screen. As nothing else worked and I figured it couldnt get any worse, I tried this as a last attempt to save it. Obviously that didnt work.
well huge geolocation changes should not influence it since it's looking for the same magnetic point as reference, which should not change.. as for it telling you on the app did you try moving it around somewhere else, i found almost anything powered will impact the compass in the spark. things that can give you weird compass readings tend to contain metal or have energy flowing through it. as an example, my mavic pro complains to no end about compass error sitting on the hood of my car if have the car running.. but if i move it to the dirt path 25 feet away it's fine.. or if i fly away its fine.. same thing today my GF took my mavic pro out and flew off of a bridge and it complained as expected until it was a few feet away..
i dont have a spark anymore to test more stuff out with them, but i do know that sparks only have a single compass, so you have to be more cautious about improper calibrations. GPS heading is ignored it uses compass heading..
i suspect that is why you had a flyaway, calibrated it when it actually didn't need it. it probably did ask you to move away/recalibrate with an error though so DJi needs to be more clear about what is the correct action for the spark specifically.. because the spark has no redundancies for miscalibration unlike how the mavic pro does. i hope DJi replaces your drone for you for free, i imagine it was a geniune fly away and you did follow instructions i via the app (which are not specific enough or clear enough). however if they do or you get another spark, before you recalibrate anything, move to a diferant location away from possible interferances, then try again if it is consistantly barking at you even in a clear area then recalibrate..and remeber it shouldnt matter with large geolocation changes.. |
