ImHereToCrash
Flight distance : 5381368 ft
i wsnt recording because i was still testing how i want to use active track with surface streets and fingind the right streets. i found what seemed to be best open street today very little in the way of cars, double lane and semi abandoned back road. weather was overcasty supposed to more sun but watever softlight is the best for active track i figured, winds calm but occassional 2mph breeze. figured ok ill have my GF do her morning jogs and ill have the mavic follow her, did that but found the mavic was struggling to maintain a set distance but it was acceptably smooth. i thought well maybe cuz she jogging to slow maybe active track likes faster moving things so i told her to sprint hard as she can, my theory seemed solid since the mavic kept up and was not panicy and was smooth, but only for sprinting.. so then she wanted to ride her bike see if it kept up smoothly with her on that, and it didnt seem to however it was finchy and panicy lot of self breaking and and sport mode level racing to catch up. i wasnt touch any sticks she thought i was toying with her, but it was on its own panicking.. i felt like ok scary it started acting really weird but its following an exact path so it isnt completely out of control. boy was i wrong, since nothing right there for the mavic to ram itself into so i had to track my car.. this is where things go crazy! it started swerving side to side almost rammed into back of my car and panic breaked its self swerved way off the road then back.. and it was super twitchy even hovering in place after that flight.. entirte time i had it track my car i had constant 20mph set on my casr's cruise control and i even slide the mavic pssed priority to 20mph just incase. my gf had control of it because she saved the day with it panic swerving so didnt strike a tree and got it behind us, i had her land it. yes a tree i felt was of no issue, 20 some feet away was too close for active track to trace us.in a car with.. and we did a close check of my blades because i felt like since i had one blade cracked on its own without nailing anything last time, maybe another blade cracked on its own and causing erratic behavior.. sure enough! rear right blade was cracked but not alot, not as deep as the last crack but definatly a crack, it is weird because the last crack i spotted wasnt causing twitchy panicy behavior and it was catching so much air that it was making a differance sound hovering, this crack isnt creatign a differant tone so not much if any air is catching on it, i think but it is still causing odd behavior.
TL;DR version: check your blades on your mavic before flying, specially in active track mode useage. i have had 2 blades on there own (as far as i know) crack themseves from general use, havent struck anything yet with them or with the mavic body. dont just assume the blades dont crack because of nothing. and yes before people ask, these are included blades with the brand new mavic pro, not aftermarket blades, it happens, every manurfactor has a few that slip through. i cannot 100% say cause of the erratic behavior was due to the crack, i have a good feeling it probably was related... but it is possible maybe my active track isnt functional or maybe something else confusing my mavic.
sidenote: my GF is right, same corner of the mavic as last blade maybe my mavic having issues with rear right side? anyone know how to test for that?
