Charles Adams
Flight distance : 3821312 ft
I performed an experiment/test. I ensured that I was not under flight restrictions, then I landed the craft and replaced the battery (I left everything else connected and running). After starting the craft (and everything synced up), I set home point and flew again. I was under no flight restrictions. Thus I was unable to duplicate your results. BUT...
I did another test, where I tried to fly around after a battery swap but not before I set a home point and not before the craft was able to set a home point (and it's tricky to do that). I found that if the craft did not have a home point set, I was under flight restrictions.
I really wasn't able to test that use case very thoroughly, so I would not call it a "conclusion". Just an observation that needs to be verified. But I think the results are: If the craft has no home point set, it will behave as though under flight restrictions.
