TheCyberKnight
I stumbled on a nasty issue this week-end with the Goggles and Spark.
During flight, I activated the ActiveTrack feature from the Goggles UI, then chose no particular traget. The ActiveTrack was active and I could see the dotted red line indicating the lowest gimbal position supported.
This is where things get ugly. From that point, there was absolutely no way to exit the ActiveTrack mode from neither the Goggles UI or using the RC - not even the pause button. The Goggles UI was also completely not operational, refusing any command from neither the touch pad nor the buttons.
I would not even receive the RTH dialog when the remaining battery level was reached. The only message displayed was the red "Critical Battry Voltage".
If confirmed, this is an important problem that could cause accidents or loss of aircraft.
Anyone else can confirm please?
